Monitor mount for ACER X34
Sneaky
Is there any budget monitor arm/mount that can hold this beast monitor?
Most mounts I found only holds up to 27 inch :(
Any advice is appreciated
koroshiya8
i think you can find quite a lot at Lazada. I was (and still) using a static mount (can only tilt up and down) bought from SLS.. about $60.
lunarsong
A bro here is using ergotech HD monitor arm for his x34.
It's clamped onto his desk
I suggest you getting a good arm which will not be cheap (the Egrotech may cost near to $200 after shipping), u are mounting a $1k+ monitor, not some other monitor.
yosemi
