Monitor no signal
princewenle
Hi All,
My monitor suddenly no signal, but the PC is working perfectly.
After goggle for a while, i tried to take out CMOS battery and the monitor is working now.
Do i need to change CMOS battery to a new one?
How did it affect my monitor?
ZrE0_Cha0s
probably some setting in the bios is mess up. anyway how old it's your pc?
princewenle
Just assemble around 1.5 yrs ago.
May i know what setting in bios is mess up?
I am using Asrock H97 performance.
Should i reset back to default factory ?
ZrE0_Cha0s
if it that old, batt shouldn't run out of power though.
well this im not sure could be some else that changes it
nah once u pull the batt and put it back, it will become default factory.
try to monitor this situations for another few days and see.
jtjt00
Suspect motherboard leakage, causing CMOS battery to drain fast when main power is off. This happened to my friend rig with Asus motherboard, only 6 months and battery need replacement. Subsequently, last only 1-2 months before being flat again.
