Monitor recommendation for PS4.
ITretard
Any recommendation? Preferably low display input lag. Been looking around for TVs but seems it pretty expensive. Is it a wiser option to get a monitor instead? :o
shadow84
Ps4 need to bother about input lag meh??? Just get a 23" will do? Maybe Dell s2340L at $179, safra promo.
As long as the monitor has hdmi can le.
orangina
Can your ps4 Boot up immediately? if not then the input lag is negligible
Nowadays TV so cheap i don't understand why you are contemplating.
A 32 Inch full HD LED SMART TV is only ~300-400
ITretard
Okay, thanks for the advice.. Wasn't sure which is more worth the money to spend on.
Desaturated
anyway dell u2410 can support? cos the native resolution is 1920x1200 while ps4 only support 1920x1080. When playing on ps4 will it stretch or having 2 black bar top and bottom?
someone can confirm this bo?
shadow84
In terms of gaming or movies???
shadow84
gaming. will ps4 graphic stretch when using 1920x1200 monitor or will it stay in 1920x1080 res with black 2 bars?
IIRC, you can set it to either stretch to fit in, or display with black bars...
And since when PS4 can game in 1080p? Isnt it locked to 720p or at most 960p for certain games...
Desaturated
oh haha i thought ps4 all games render at 1080p since it is the 'standard' for pc gaming now. damn :(
shadow84
MX279H is 1080p at 27". It will look more pixelated than a 24" on 1080p. Also, the price aint cheap at $399? Better off getting a 24" monitor, if u r sitting near to it. Otherwise, a 32" tv would do.
ITretard
I'm hooking up with a pc. That's why I kinda give up on TV. Might be too big. Something 27" pretty decent.
