Monitor spoil
majora
As I am typing this, my monitor is displaying a distorted image:
Some troubleshoots i have done:
-Graphic card temp is normal by using hwmonitor
-I unplugged the DVI cable and tried to on and off my monitor, there is the same distorted image at the 'Acer' word before showing 'no signal' message
So I can safely say my monitor up lorry liao right?
MoneyFace =p
Looks indeed like screen issue but can double confirm using just IGP? No need reinstall driver, just plug in and see if distortion still there.
jtjt00
If you got a laptop, connect it to the monitor and see if image is fine or distorted?
