Monitor sugguestions for upgrade
evancjx
For gaming.
Currently using GTX770 and PnP monitor, would like to upgrade to GTX970 soon.
Have set my eyes on BENQ Xl2430T... is it worth?
sglords
What type of games u play?
E monitor u eyeing on is 144hz wor. Hard to drive with single gtx970.
shadow84
In order to get the full advantage of 144hz,you need to be driving 144 fps. That is hard for a single gpu unless u use low to med settings which also defeats tje purpose of spending so much on a 144hz monitor.
evancjx
okay. i see. which monitor is best for GTX 970?
evancjx
U2414H is good enough, imo. Unless you really want 144fps@144hz.
http://www.reddit.com/r/buildapc/comments/2haovw/discussionwhich_gtx_900_series_should_i_get/
this discussion says gtx 970 can run 1080p at 144hz?
evancjx
So now either ASUS PB278Q, DELL U2715H or BENQ XL2430T
monikernemo
At max settings, hard to drive 144fps. Also depends on games. Not all games are equ
l.
2715 60hz leh. And 1440p.
Anw GTAV no need to go 144hz, 60hz is good enough. At 144hz, you are sacrificing a lot of color (mostly TN Panels) for refresh rate.
Sent from your wardrobe using GAGT
