Monitor touch settings spoilt big problem
Phen8210
Recently my monitor will activate the settings by itself.. very irritating. it will block the screen halfway when i game.. just now i got kicked by my team because of that.
It automatically change the input to VGA when i using DVI.. then the screen went black :vijayadmin: when i was gaming :(.
The settings just keep triggering by itself and it will also scroll through the options by itself..
Now it is stabilized, happening less often. But sometimes it still pms. I've cleaned touch area with alcohol swab and everything already.
Anything i can do about this??
bigpelican
it happened to me. the menu activated on its own and cover the part of the screen. i open the monitor panel, plug off the circuit connection. the button is not working now, but the menu will not get activated.
you can search youtube for how to plug off the button circuit connection.
