thickness comparison - Silver Dragon vs UE11 wire.
Silver Dragon wins.
Will collect mine 2moro too. Lets hope these "hype" is worth the anticipation ~
cable burn-in has no effect in sound.
unless the cable is made of such low quality metal where by just having current passing thru it would cause the metal within to oxidize due to the difference in charge... then yeah, you are literally burning in the cable.
chemistry.
I can show you the difference easily.. but what do I get if you tell the difference?
If you win, the cable is yours for free.
hi guys i just got my SD from stage93 so i thought i should post some impressions.
firstly, the build quality is damned good la. the cable is thick and it feels like the kevlar cable used on the IE7 / IE8 .
In comparison to my ES2, overall everything is slightly louder, probably because of how thick it is and the high purity silver.
It might be my imagination, but bass impact seems to have increased. and the highs are a little harsh.
Will burn-in cable and post any other findings![]()
i gotta admit that I was skeptic but i tried out on my M2 and my gf's m2 there is a noticeable difference because she uses her m2 more frequent than me. I use my tf10.
OMG!! guys pls post your findings on the sound quality pls. I have the Null audio lune i wonder is it worth upgrading to the SD.
my cable technology now is unidirectional - each side got different sound - 1 cable 2 sound.
so how to explain?
If you're an EE grad, then how explain the science?
burning in cables are true story.
can hear difference de!
