Motherboard Crazy Temps
valkarian
Just went to do some basic cleanup for my friend's computer, when i saw these temps. Temps like these cannot be natural, yet when I checked the case airflow it was still ok.
What gives? What do you think I can do to remedy this? Reapply thermal paste? (but the temps don't seem to be coming from the CPU, in fact CPU seems to be running hot because of Mobo temps)
wkweewee
Can be a case of a cranky temp sensor or false reporting though..
wkweewee
Agreed, But just in case, in a worst case scenario and the mobo is actually running these temps?
Actually u can go inside bios, attached a pwn fan, go to fan settings and set the different fan speeds at diff temp. When you are done, rs the pc and is the fan running at max speed like one heli?
Anyway you can install ai suite/ other temp monitoring softwares to chk and see as well. But I gt a feeling it is still more geared towards buggy reporting.
Ark Law
Krabs.
it's software fault
because those sensor does not directly report in readable format "85 degree celcius" to the chipset ....
the software must be compatible with the chip to accurately decode the data
use hwinfo64
the developers make the effort to make it compatible with a wider range of sensor chips , while other lazy developers (like hwmonitor) don't cover as wide ... resulting in many users reporting error
