Motherboard Problem?
GhostDDan
Hi bros,
Just need your expertise in determining these symptoms. One fine day, my com suddenly starts dying on the USB connections ( Example: My hard disc, mouse, keyboard will off by itself and after awhile goes back on )
Then randomly, my graphics card crashed to a black screen with an immovable mouse.
And last random factor, my SSD containing my windows crashes, whereby sometimes at start up it couldnt detect my SSD.
I had made a huge upgrade last year buying a couple of new parts except for my motherboard manufactured by Acer which is around 6-7 years old. So is the problem got to do with the motherboard or my PSU or something else?
Here's my hardware specs:
Processor
Intel(R) Core i7 CPU 920 @ 2.675GHZ (8CPUS)~2.7GHZ
Graphics Card
AMD Radeon HD MSI 7970 Power edition 3GB
Memory
4 X Kingston DDR3 1333CL9 4GB
Casing
Coolermaster HAF 912 Advance Chassis
PSU
Seasonic X-Series 660W Modular Power Supply
OS
Windows 8
theuser
seems like it, you can try to go acer website and see if got any bios update for your mbo.
however, i suggest you to get a new mbo and like you said its around 6-7 years old..
jtjt00
TS, return to stock speed if you overclock.
Is the Acer mobo come with onboard vga?
If so, remove your MSI 7970 and use onboard vga.
If this fail, remove 3 pcs of ram. Swap if fail.
GhostDDan
Doesnt have vga and didnt overclock
Oh man I really think I should get it replaced
Steyr69
Processor
Graphics Card
Memory
Casing
PSU
OS
Windows 8
your mobo must be very top end at that time to support DDR3.
i dunno....i work in reverse mode....upgrade the mobo before touching anything else.
GhostDDan
Yep it was, some acer gaming pc series that cost me about 2.5k
Acer Aspire M7720 if I am not wrong
Any recommendation for the mobo upgrade? I'm abit blur if the motherboard comes with the processors
Steyr69
your cpu is lga1366?
a bit problem as 1366 mobo is like no more....unless you buy from open market.
you are better off buying a new ivy bridge combo...mobo + cpu....a lot of choices.
vitadrink
sorry but I hijack a bit. I don't wanna start a new thread. ;)
Anyway, I face the same problem but not as bad as TS'.
Mine is when I play games halfway or even idling, my computer just crash and the fans suddenly become very loud. Then when it tried to reboot, sometimes it works, sometimes it will have 1 long beep. Then I resit the ram and sometimes it works sometimes it doesn't.
Also, when I boot into windows, rare cases one of the SSD will not be detected. Is it a motherboard problem as well?
Steyr69
your hardware looks ok.....
what kind of games are you playing?
i see you using onboard video.
Maeda_Toshiie
I thought Nehalem based CPUs' RAM controllers are all DDR3 only...?
One long beep -> check who made your BIOS and then search for the beep codes online.
GhostDDan
Ok, I decided to replace my mobo with budget of $3xx to $5xx ( Which I think I finally should as part of upgrade )
Any recommendations for me? Do i need to consider what limit my PSU can supply?
