Mouse recommendation
Phen8210
This.
I also recommend Zowie. Either the FK or the EC series (SLS also has a ZA series as a variant of the FK series)
Pick according to your hand size. Those mice are so simple, accurate and awesome. No rubber coating or crap to wear away. They just work.
can change dpi too at the bottom, 800,1600,2400,3200
MrMundy
Any other really big mouse other then MX Master?
https://www.anker.com/products/variant/2.4G-Wireless-Vertical-Ergonomic-Mouse/98ANWVM-UBA
honestly, u want to buy mouse:
office - mx master 2s/ mx anywhere 2s
game: zowie ec1-a(bigger, same size as razer deathadder/chroma) or ec2-a (smaller variant)
other mouse can jiak sai
but tia gong logitech g pro and g900 also notch bad, but never try before:
http://gaming.logitech.com/en-sg/product/pro-gaming-mouse
http://gaming.logitech.com/en-sg/product/g900-chaos-spectrum-mouse
in any case, dont bother buying razer stuff, overpriced, overhyped, mouse has double click issues, keyboard usually last 1 year plus before some keys will fail
steelseries mouse moi using their rival 95 (pc bang version of rival 100) for daily use (not bad, sensor is ok, no double click issues but i dun like the clicky sound and feel when clicking), if play game then take out the zowie mouse
EDIT2: dont ever buy the logitech marathon mouse, ** 1, the sensor is off centered, and super inaccurate, wasted my $29
dawntime
If you happen to want wireless and optical sensor, do check out g403 prodigy wireless.
OceanEleven
Thanks for the input. Am using the G900 and MX Master now.
But still wanna look for a bigger size mouse to try out. :)
MrMundy
Ur hand so big ah, MX master is considered tua Leng gong alrdy, u want bigger means buy those plane simulator joystick riaos :s13::s13:
OceanEleven
Is quite big, when all fingers close, measure from thumb across the palm is almost 11cm. Matter of fact, widest part more than 11cm.
