MS Script Comfort Keyboard Issue
Molely
Good morning to all,
I had a problem with my 2 X MS Script Comfort Keyboard. :s11::s11::s11:
when i press on 'R' it will show up as '66r'
button 'T' can only be pressed once and will hang there.
button 'K' will toggle full screen.
'Backspace', 'Delete' and 'F2' buttons cannot work.
not too sure what other buttons are stuck....
this happen to my main desktop yesterday. :s22:
and since I had 2 desktops using the same model of keyboard but at different room.
I exchange my spare PC keyboard to the main and vise versa.
both having the same problem on both PC too.
had google a bit on it, tried reinstalling driver and update.
restart, change language options just does not work.
sticky keys and shortcuts all tried also.
my main PC is working find in the morning, evening when i came home and this happens.
for my spare PC, last i used was on thursday and its also working properly.
cannot be suddenly 2 of the same model keyboard spoil at the same time.
one is bought in 2013 while the other one bought last year.
hope any bro/sis with such problem can advise and help.
thank you very much
hlots123
if both systems affected, cud be win10 is syncing windows settings between ur PCs. try look around if settings are correct, eg...
start> settings> time & lang> regions & lang
start> settings> date & time> time zone
start> settings> ease of access> keyboard
Molely
nope, never installed any program.
yap, check both PCs are all same settings. :(
