Multi Port Charger
cruizer_ph
I used to use this 8 USB port charger from Shopee/Lazada that has a display showing how many amps each port is drawing. One time my daughter thought it was smoking so I threw it away. I belatedly realised it was the USB cable at fault (which was emitting smoke) not the charger. Too bad :(
It doesn't support the QuickCharge stuff though. Max is it can draw 2.4A per port.
galaxyuser
The Aukey PA-Y12 three port charger (one USB C PD port that can charge Note10+ at faster than 25W speeds), and two USB A ports that support Qualcomm Quick Charge. Only for 69.90 or cheaper.
Hi guys , what multi port chargers are you guys using ? Any recommendations ?
DarkMage168
I've got Energea PowerHub 4PD+ 75W with 4 ports. Local brand that has 1x USB-C with USB-PD 60W, 1x USB-A QC 3.0 & 2x USB-A @ SGD$79. Limited stock.
Another is Aukey PowerPort PD 4PIQ. 1x USB-C 30W, 4x USB-A @ SGD$52 Sale.
galaxyuser
AHEM, it's ANKER POWERPORT PD. Aukey never uses PowerPort in its product range.
Charlie_Zhan
Xiaomi 60w 6 ports charger.. less than $25 from TB.. uses detachable figure 8 wall adaptor so can easily get a UK plug locally.
have 1 x 18w USB C pd slot, 1 x QC 3.0 slot and 4 x 5V/2.4A USB A slots.
Audiology93
Anker 60W, X Power 4 port with qc3.0, RavPower 60W
Sent from Xiaomi MI 9T PRO using GAGT
