My First PC Build
dayam15
Hey guys,
Been playing DOTA 2 on my 6yr old laptop with a 920M and although I can play on low settings fine, it's come to the point that it's starting to get laggy. I also want to start getting into a few FPS games.
With that in mind, I thought of building a budget PC with plans to upgrading in the future if I really get into FPS games. Here it goes.
Ryzen 5 3400g + Asrock B450M Steel Legend = $355
KLEVV BOLT 3200MHz CL16 8GBx2 = $105
ADATA SX8200 PRO 500GB = $135
CM Masterwatt 550W Bronze = $82
Texware M3+ = $59
Total = $736
I went with the APU since I mainly just play DOTA 2 for now and think it's sufficient. I should be able to save up for a GPU in the future if really needed. The prices are based off Dynacore price list online.
Thoughts please! Thank you!
NightRaven49
if ur going for an apu only build, 550w is a bit much, also i wouldnt trust cooler master except their mwe gold line. i would suggest dropping down to 500w or even 450w, and if ur already paying so much, u could consider the corsair cx450m, which is also semi modular. 450w is also enough for 1080p gpus like the 1660s or rx580 if u wish to upgrade in the future.
other than that, looks good.
dayam15
I can't seem to find anything lower than 500W from online price lists. Can you recommend anywhere I can find one?
What about EVGA BV 500W 80+ bronze, it's priced at $69 from Dynacore.
Koenig168
You might wish to wait a few days. Renoir is rumored to be out on 21/7.
NightRaven49
personally got a cx450m from tradepac for $80, i think bizgram also have when i went last month, but more ex at $93.
most ppl would recommend fsp hyper k for really budget 500w at $62.
