My HPdv5 is overheating!!! Help!
daveberla
hello!
my pc is over heating..and doing a lot of noise from the fan!!
how can i fix this problem!?
thanks
Davide:s22:
Little_Ambitions
it's a simple problem. if the fan is making noises, the fault probably lies with the fan
have to disassemble the laptop and change the fan.
can send to SLS to do it if you're unsure.
can try out the shop at level 5, they do the disassembly on the spot, Empire IT
