Thanks for the reply. I need clarification on #4. New contract means the 1Gbps plan? Recontract means which plan? Existing 100Mbps plan at $59?
New contract = terminate line. sign new 1.
Recontract = continue with MR services but change plan to 1gbps
Thanks! Quite clear now.New contract = terminate line. sign new 1.
Just some feedback on China YouKu website.
Watching at Gao Qing for 20 minutes and only buffered twice for less than 15s.
yes you can do so.
Great, can you tell me how to recontract, since 2 out of 2 times when I approached the MR online support chat staff, they told me I needed to pay one-time fee (even after I told them my contract is ending in April and that I already am an MR user)?
You can recontract at https://secure.myrepublic.com.sg/order/.
If your installation date is before your contract ends, you have to pay the one-time fee as this is an upgrade. Otherwise, the one-time fee is wavier off as this is a recontract.
Is there a need to install stuff since I'm just recontracting? Not quite understanding how this works.
For those with the 1Gbps up, we want to challenge the connection a bit.
Can you try some doing some "heavy duty" things using the 1Gbps? Speedtests are just tests after all.
E.g. play an online game while downloading large files in the background, torrenting >10 large files at the same time.
Let us know how it goes!
MyRepublic appointment
Migration - New appt / 2014-04-02 Edit MR appt
Appointment time Am1 (9am to 1pm)
Reachable X
Contractor Flexatech
Installer name / mobile null / null
Installer arrival time
Work completed time
Arrived within timeslot
Remark
It's impossible to get such speed to china. it's cache. =) similar to the other 2. as mention, the only solution is cache.
From what MR support staff told me they are using private proxy for dynamic ip. Hence got problems with access to china websites.
Which BTW why MR do not use public proxy for easier access to china websites?
.... is this their strategy tat u have no way to terminate? I'm on the old gamer plan and i'm experiencing very bad latency in diablo 3, could this be looked into? i'm connected via lan
for the sake of comparison would the new ONT offer any advantage to over the old ONT if both are on the same plan?
