MyRepublic fibre - Part 4
ithrux
Yes. If it works with direct connection to ONT, that means your side managed to receive the dynamic IP that MR DHCP servers dish out.
You mentioned that it is not working with connection via the router. Do you mean wired or wireless connection?
Tested with both wired connection (different ports) and WiFi if you have not done so.
Thanks.
PC to Router by both wired and wireless doesn't work, simply because the router is not able to get connection to MR even though ONT link is up and active.
Can't be the crossover cable problem since this is not the first time it is happening.
xRenol
Can you use the Ethernet cable between the router and computer to do a direct connection to the ONT?
ithrux
Precisely what I did and it worked, and said on first post.
I'm suspecting router MAC address conflict or something, which totally baffles me.
xRenol
Sorry my bad if I missed your first post.
That means the Ethernet cable is working.
Previously I also encountered a weird thing with my router - no connection via router on wired connection. After I reset my router, wired and wireless connection works with dynamic private IP. When I set my Static IP on the router, wireless connection is working but not wired connection. Changed back to dynamic private IP on the router, wired and wireless connection both not working.
In the end, MR technician came down to change the router and everything is working fine again.
ithrux
No worries, just waiting for a callback. Since it's probably really hard to get through on the line now.
WindJammer
Hey guys need some help.
I had just got the static ip renewal.
I had input it in the router page together with the rest of the information like subnet, gateway, pri and sec dns from my previous setting.
After rebooting, my internet connection was limited. Did I miss out something???
I was on static ip previously, but for this time, I had just input only the new static ip and the rest of the info follow the previous ones. I had also input the new mac address which come from the new router.
nivleK1985
Hi guys,
I understand that there may be issues with the AC68 as acknowledged by Asus.
Thus, Asus is working with our product and engineering team closely to fix every single issue resulted by the firmware released by Asus.
In addition, I will swap my N56U router with a AC68 later to test the connection for the next few hours (After my dinner =/. 9pm liao, i haven't eat yet ) and check every settings and see if there's any issue that can be raised to Asus too.
As for Fiber take over issues. We noticed a very high rate of rejection of FTO from other service provider.
For FTO to work, the other service provider must agree to let go of the line before we can take over.
As they are not obligated to inform us of the reason for the rejection. In the event of rejection, we would need customer's help to contact the various SP and request for the reason for the rejection and let us know what's the reason such that we can escalate to OpenNet/IDA if the reason is invalid. While the frontline CSO may not know of the reason for the rejection ,kindly request to raise the issue to the one in charge of the FTO process.
niezh74
Gosh, didn't know that connection to China sucks. If that's the case, I really want out.
micheloving
Not sure if china sites such as tudou(anti foreign IP) is throttling my speed or is MR problem.
But china site streaming is indeed terrible .Barely can stream anything through VST android app too .
Other IP got such problems?Anyone from traffic light or VQ can verify this?
ianlim_88
Hi, for my case (C1010426) have MR started the FTO process but got rejected by Starhub to release the Port 1 which they used before? If this process had already been initiated by MR please give me some details or case number so that I can contact Starhub to resolve it myself instead of wasting time waiting. I have wasted 2 days of annual leave for no show by you guys. Btw, I am also in contact with OpenNet to see where the problem lies for this installation and who should be accounted for the delay.
Hi guys,
Phen8210
hi nivlek, i've pm-ed you. tried to contact hotline yesterday.. couldn't get through.
xRenol
Hi guys,
May I know why MR technical support hotline seems to be forever busy?
Please feedback to your management and if nothing is going to be done very soon then good luck to the continuous loss of customers.
bovi77
i am, been having them since 1st feb when i signed up with MR.
don't tell me my hardware or antivirus, i haven't changed anything compared to when i was on VQ and MR's twitch experience just plain sucks.
Just suck thumb and accept lor.
Complain a lot already but like no improvement (except for 1 week when alot ppl complain), seems like they don't give a flying !@#$ about customers.
you refuse to consider these items which worked for me. it doesn't make any sense why it should work but it did. Otherwise try to borrow some1's laptop to test. I too didn't change anything to do with my PC yet from gamer 150 to 300Mbps the internet got crippled.
you suck thumb while i'm now watching twitch on source quality smooth. can even do so on multiple PCs. your choice.
Except for billing which they are very precise and on time with.. luckily my 1Gbps is working fine except for the problematic streaming on most china sites and VPN not working at all..
Just received my first bill..
can share with me the china streaming sites to test? free one right?
Thanks bro for your reply.
I am using 1Gbps connection.
1. How much did you pay the contractor for the wiring? So you did not punch any hole through the wall?
2. How do I check my Network card supported bandwidth/speed? Because mine is a DIY PC about 2-3 years old.
1. I laid the wire quite casually. run along where the wall meets the floor. i did not punch any hole. might seem unsightly to you lol. go find the cat 6 flat cables at sim lim you'll be able to imagine better how it will look like. cat 7 flat cables are fatter than the cat 6 flat kind but acceptable (still much better than normal lan cable). if you really want custom length, you can buy extra long then go to 2nd floor sim lim shop that can customise for you as I'm not sure if they have stock of the flat cables. the cat 7 flat cable was thin enough to go under my door. I'm using Morelecs brand. $30 for 15m cat 7 i think. cat 6 cheaper and i would have bought cat 6 if i found them 1st. 2 shops on 4th floor sell them, 1 selling printer ink & mobile accessories and the other is chamoxa.
2. Your network card (LAN) should be gigabit. my pc 5 years old i think already and it has a gigabit card. google the model of your motherboard and check the manual. The fact that your speedtest.net hit more than 100Mbps means you are on gigabit. If you are talking about wireless network adapter then need to google the specifications.
WindJammer
Do you all have the following issues?
I was on static ip previously, but for this time, I had just input only the new static ip address and the rest of the info follow the previous ones. I had also input the new mac address which come from the new router.
elimmel
MAC address must be of new router. Maybe check that again.
I had this problem previous round and called MR. The MAC address on their side was different. (Gave them wrong one I think).
WindJammer
For the 1Gbps, i had call MR previously and he it will be automaticall assign, no need to provide mac address and i had double check that i had enter the correct mac address in the router page.
Seems like nothing going right :(
hangyong
restore the router to factory default...
when booting up, just follow the instructions and set up the router.
DO not have to put in the MAC address.
did you try connecting directly to the ONT port 1 and see if it is working?
Boltersdriveer
Just FYI, on the new 1Gbps plans, for Static IP to work after changing equipment, you'll have to give it about 5-10 minutes (power off the equipment). If you keep trying within the timeframe, the more it won't work.
Bolts
WindJammer
Already restore to factory on Monday therefore the router shld be "clean"
for new static ip address. With and without the router MAC address also got limited connection.
ithrux
MR Team,
I need a callback from 1 of your tech guys. CID: 3655
Router to ONT - unable to establish connection to MR
Direct to ONT - Connection ok.
Power cycled router/ONT - doesn't resolve.
This happened last Sat morning, fixed itself late at night. And it occurred again this morning. Router unable to get IP from MR.
Suspect it has got to do with my router's MAC address on your network.
For MR staff..
