MyRepublic fibre - Part 4
angeltst
you probably need to opt for static ip else your entire home is under an "umbrella". gamer plan or not, you need to apply for a static IP from MR due to their unique setup...
How do i opt for static ip from MR? Is it chargable?
xRenol
1. Yes. opennet only recently installed the TP after i renovated the house and they checked the signal and told me was ok.
2. No. New subscriber
If OpenNet has checked the signal, then why do they need to go into your house during the installation date? Normally, OpenNet will activate or connect from their back end system.
There is an one-time charge of $50 for Static IP. Static IP
WindJammer
Basically the speeds are more or less the same with 2.4/5ghz N unless you have a ac wireless adapter
My experience since last issue of slow connectivity and the advise from the members here,
Direct ONT - 700Mbps
ONT - AC68 - N53 USB adpater - Range between 120 - 150Mbps on 5ghz
ONT - AC68 - AC1200 USB adapter - Range between 260 - 350Mbps on 5ghz on a good day.
Using the AC adapter, file transfer to asus aicloud from my lappy yield a speed of ave 18Mb/s
torrent speed is 18Mb/s.
Of cos the USB 3.0 probably plays a part on the AC adapter against the N53 which is on USB 2.0
Still, not sure if the speeds is good enough. Whatever it is, i can live with it right now.
cyberet
aicloud meaning usbdrive on router? i believe its the router cpu limitation
xcrozx
I recently got the 1GBPS fibre installed, getting quite good connection, but I noticed the router is getting quite hot. Is this normal?(never turned it off)
Using Asus ac68u
mashpotato120
Please allow me, someone who is in the "haolian kia" gang to answer the golden question of if there is really an improvement in their new 1GB plan.
1) 1GB will and definately is a LOCAL benchmark results only, the international bandwidth is pretty much the same as before.
2) But dont forget, at the attractive price of $49 / $59, what you're paying for is surely cheaper than all the other competition out there.
3) And what you have now is the opportunity to exceed your current speed (i.e. current MR user) at the same price point. This is a free upgrade. Remember you now have the capability to download something @ 1GB speed from local host.
4) Depending on where you get your "sources", conventional downloads from google drive / daily motion / premium file host / torrent. I'm seeing easily a 100% increment or more, from 15MB/sec to 30++ 70++ MB/sec.
5) For streaming wise, im not having any issue from watching twitch.tv. But watching other streams @ EPL is still shitty like before. PLEASE SIC if you have a stable HQ source. Thank you.
6) For online gaming, there's hardly any diffence as they are using the same routes.
7) And lastly, ask yourself if MR is suitable for your internet usage in the past 2 years. If they are, please continue to support them as we really need such non traffic-light ISP in SG. If they're not, please consider a change of ISP to the "dark black side", chances are if MR cant produce the improvement you seek since day 1, they will never be able to in the foreseeable future.
PS. The world is unfair, user not opting for the upgrade are at a disadvantage (both speed and pricing). Please be firm but not rude to secure your own timing and installation date. The reward of getting the 1GB up and running is worth every phone call / emails sent to MR.
PPS. I seriously dont mind if people move over to the other ISP. Larger customer base = lower standard and bandwidth.
Lehnsherr
Using Asus ac68u
Think its normal, it has a heatsink inside BTW. Its predecessor the N66U first revisions even have fans I remember reading somewhere :s13::s13:
Destinyrider
i am thinking of signing up myrepublic 1gbps. i read up the HWZ has bad reviews about the installation and some good reviews about myrepublic. i am abit lost right now. so is myrepublic good or bad ? :s11: is the international speed 1gbps also ? should i sign up the 1gbps ?
mashpotato120
Hi hanyao,
No such thing as 1gb internation speed, even for other ISP. Especially not at this price point.
It really depends on what you use your internet for, and how much time you have to handle MR "over whelming responds" if you sign up now.
To add on , MR is good when everything is fine. Like right now, after some improvement to china streaming, you see lesser people raging about it now. And we are just waiting for the next cycle of complains when the improvement is gone.
Destinyrider
Hi hanyao,
hi,
are u on 1gb MR plan ? whats the international speed ? is the speed stable ?
looking to sign up for a fiber plan. the cheapest is $39, MR 1gb at $49 so want to try it out. but still have some doubt over the speed is too good to be true and the reviews on MR lol. i use it for gaming, youtube, torrent etc.
mashpotato120
hi,
Hi Hanyao,
Yes i'm on 1gb gamer. I'm not sure whats the answer to give for international speed. You have a specific link which i can test?
So far its stable for me, excluding the initial few teething issue which are mostly fixed now.
The advertised 1GB speed is definately marketing lingo with lots of smaller print. 1GB is only possible for local connection ++ suitable h/w to go with it + lan cable connection only
Based on the 3 usage that you listed, i would vote MR over M1. Especially if you torrent. (please refer to M1 thread for more positive / negative sample)
Only positive factor which M1 is better than MR is their china routing and streaming.:s12:
Destinyrider
Hi Hanyao,
sry what is the meaning of h/w and it as hightlighted ?, lastly for the $100 Router Voucher, is Asus Ac56u enough to reach the 1gb speed ? or should i go for other model ? and roughly how long is the waiting time take to installed after i sign up or do i get my schedule date on the spot ? thanks very much.
reggaez
Hardware meaning the router can support 1gbps speed anot? also your home's wireless or wired coverage is it capable to support 1gbps?
honestly all your questions should be directed at a MR's Sales person.....
u can also read from other reviews that large number of users have issues with installation dates. for myself i am waiting for end of my contract before considering my options.
