MyRepublic fibre - Part 4
arsenal_sux
try speed test using this link?
http://speedtest.myrepublic.com.sg/
if use speedtest.net....like some server will give only very slow speed sia :p
if they configure back end liao should get this de
5847315
Hi Bro,
This is the same result im getting on the Speed Test. Is this due to backend where they havent activate my 1Gbps service?
keanteac
Who did you PM? I had luck with nivlek1985.
But honestly don't hold your hopes too high on a fast upgrade. Mine was a smooth sailing one and from the time I bought up the thing on upgrade to nivlek1985 to the actual installation day it took about a month.
So in your case which is unfortunately a problematic one, you might have a longer wait.
The biggest problem now with MR is they have completely disappeared from this thread, leaving those with problems none to turn to, and those without problems feared of having a problem.
The hotline super hard to call in.
Worse than the bank.
The_King
MR, when are you closing my case? i cancel my order and needed to pay $297. it been 5 days since i last hear hear from your billing dept.
imacbie
I cannot believe I am typing this.
I feel angry, but I know there's nothing I can do, just have to sit through and hope things will get better.
Came home from work, tired, just wanna stream some variety from china,
All I get is non stop buffers.
End of rant.
seller4
Thanks for the tips. I have Options 1, 3-5 done. Im going to do this, will rebuild my Laptop from scratch again and post another test.
Btw, plugging direct to ONT should be fast, but im not getting fast speeds. :(
Could be a faulty ONT.
stanoi
My Repubic too soon
My republic is not living up to the speed and claiming what they cant keep up . My be singtel ( open net that it manages ) is screwing them over and the toothless IDA as usual protecting Singtel.
Those are possibilities to investigate
Singtel and Starhub is pissed that My republic has some policies that liberates internet and breaks their monopoly . Hulu and Netflix becomes possible at My republic
However My republic is screwing up more and more. initially I had praises for them.
Now I see more interruptions , total loss of internet often .
And Indication that they are messing up and cat swallow when they chewed .
They are most likely stretching themselves .
! way is to create a Ping log. from the router to see if the network is up and log all to support complaints to IDA
What IDA might do can only fall within a few pretty straight forward to guess knowing what I have known them to do .
whoooo
nope it wasnt dota 2. But now that you mention it, i noticed it with dota 2 too. Did MR change their route or something?
Definitely as my battlefield 4 on sat and sun i can see enemy gliding across me and enemy cant hit me lol...wtf.
diamond96
I'm getting ridiculous low upload speed ...
Called in but waited too long and I hang up. Anyone also experience this ?
Loading some page is slow and the result of my speedtest
Anyone from MR wanna solve this problem ? Or at least explain why ?
I can't download an important document now. It just keep spinning and spinning without downloading.
doki81
no point ranting in this thread...no more MR support here :p
