nivleK1985
- Feb 20, 2005
Home Voice is indeed facing some issues at the moment b
Update on my issue.
Its was resolved on Tuesday. Have been enjoying my speedy fibre connection. Thanks for the response.
For people looking to sign up, it really does take about 2 weeks to get everything running.
I hope MR can fix their SSL certificates, given the rash of hacking incidents
mine is verified. is your browser updated?
Hey bros, anyone know what the difference in speed between wifi and cabled? Even if you're near router? Not trying to kp here but sometimes speed like quite different even on my computer, very weird leh.
Yes. In fact if all your device are using N. Any user adding a G Device into the network will cause the speed to drop to G. slowing down to the oldest device to be compatible.Hey bros, anyone know what the difference in speed between wifi and cabled? Even if you're near router? Not trying to kp here but sometimes speed like quite different even on my computer, very weird leh.
Thanks for your help bro! Quite useful things in there!There bounded to be difference speed when you on wired compared to Wifi.
You can you use the information via this link
https://secure.myrepublic.com.sg/speed-booster-guide.php
I see... Thanks bro!
Please do call me if you need any help.
Wah. Is this how the electronic companies pa ka together to make people buy more stuff? Sia la now must go back check my parents laptop now.Yes. In fact if all your device are using N. Any user adding a G Device into the network will cause the speed to drop to G. slowing down to the oldest device to be compatible.
Think someone should create a short explanation of wireless vs wired and paste it every time someone post about wireless... too many people asking about it all the time.
Quick one for the tech heads:
OpenNet came by and installed TP yesterday.
The signal was tested as follows:
OTL -18.52dbm
Technician told me a reading below -30dbm is good but I saw pics of other TP boxes showing signal as low as -14dbm.
I know one shouldnt get too bothered by numbers but I have to ask:
Is -18.52dbm signal strong enough to give me the kind of speed boost that supports seamless streaming? Thanks
