Hello!
Not sure if it's alright to start a new thread. Hope I am not repeating questions others have asked.
Bought N7102 from China, It's a dual sim Note 2.
Problems i am facing,
1, most things related to Google is disabled. I don't have play store, gmail, not even chrome!
What's the options available to get it back?
2, the phone works fine, i managed to download apps from Baidu and some other china andriod markets. But i am having problems with local SG apps, like those mBanking apps, ST, etc... can't seems to find it anywhere beside play store (which i do not have)
Is rooting the only option?
I've been using iphone since the original iphone to iphone 5. First time using Andriod, so far very happy with it, and would have bought a SG note 2, if there's a dual sim option available.
Thank you for reading.
, 1st the map location doesn't work at all,the stock browser isn't using google search and playstore might not be important to you since you can find apk ard but a lot apps determine your location will not work if u didn't root to solve this issue.
