Hi guys,
I've reseat my cpu, cleaned all previous paste and reapplied new thermal paste. I used the cheap $5 CM Thermal Paste (White).
Also vacuum TONS of dust haha.
Earlier today, I've tried using PEA method on the much expensive $12 CM Thermal Paste (Bronze), the temp appears to be +5~15 much higher either idling or in games.
I took it out, cleaned again, and applied with the cheap white thermal paste, this time I used the spread method. The temp appears to be -5~6 cooler than the screenshot I've posted here.
I have yet to try in games, so I will proceed now and check it out.
I've google and found that the CPU proc itself might be faulty, as my room is always air conditioning, and if I were to really compare, I should be sitting at 20+ degree. But I'm still at 37~45+.
I suspect my CPU proc is faulty, never the less, motherboard could be the cause.
I will monitor this, and since I might be changing to 4930k anytime soon, I will update this thread if I still experiencing high temp and low FPS after changing.
