Need a larger casing than 450D
kouichi83
Hello everyone!
I'm looking for a casing that's larger than corsair 450D and preferably with nice appearance as well (no white colour pls as it gets stained easily)
Additionally, this new casing I hope to have good air ventilation and less noises generated as much as possible
Will be building rig this coming weekend
Appreciate any help, thanks a million!:)
GeForce
NZXT H440 Razer Edition
Corsair 750D
Fractal Design Define R4
Phanteks Enthoo Pro
CaseLabs SMA8
royfrosty
Not sure why you need a bigger one. But anyway to add on and one size bigger.
Fractal Design XL
Corsair 900D
Corsair 780T
Phanteks Enthoo Primo
ckjoe234
If ur wallet can go deeper..
Red harbinger cross
Vector desk
Lian li dk02 desk.
FatalityV
Using the corsair 760t, there's a black variant of this case. Air ventilation is decent and aesthetics are really great
SimonLam
Hello everyone!
haha after my PM, you decided not go for 450D.. why ah?
kouichi83
bro Simon, 450D does not support H105, therefore have 2nd thought of getting a bigger casing since it's lasting and reusable if well maintained
Taken from official site for 450D's spec:
Compatible Corsair Liquid Coolers H55, H60, H75, H80i, H90, H100i, H110
Currently, i'm leaning my decision more towards 760T. Looks sleet outside and roomy inside for future upgrades
780T (yellow) was initial choice, but looking at the dimension "689mm x 332mm x 670mm" it seems rather tall and as such, the space gap to the base of my table is pretty close unless i place tower on table which compromises my table space :s22: oh well lol
So if i were to get 760T, which shop selling the cheapest? TP again?
Thank you all for the generous suggestions!!! :s13:
FatalityV
don't think razer and nzxt going to come out with that design.
can go for the alternate black/green version
Razer website got put, but coming soon for very long already, still no word on it..
but if you get that case must take note, iirc theres no optical drive bay in front so must make sure you do not want to use it
kouichi83
Err not true leh... I install h105 on 450D :)
Didn't see your rig spec on the right lol
Actually I dun mind to top up for a slightly larger casing, so more or less 760T for now unless better suggestions to choose otherwise.
Anyway I was advised by yilong from PC theme saying swiftech cooler has been months since last imported in SLS
Was looking for that..
shadow84
Swiftech not that worth it... Better off getting Corsair, thermaltake, Seidon. AT least got some local support.
