Need a small footprint PC for design work
stupidog
Have been seeking hi and low for one for the past few mths
came across this
Let's say i take this with
1) 1 x 16GB DDR4 ram @ 112
2) 1 x 512GB Samsung 950 Pro Nvme SSD @ 519
Total = 959 + 112 + 519 = 1,590
Anyone can recommend something small with better gfx ?
Budget around $1700
No need monitor, speakers, OS, KB, Mouse.
Thanks in advance !
ZrE0_Cha0s
i dun think u can install a GFX though, cos the thing is that its build to be a mini pc. and beside that it comes with intel own gpu onboard as well.
Krabs.
the HQ is laptop cpu .....
the problem with laptop cpu is they throttle when you do max load for extended period ... like gaming .... the fluctuating clockspeed cause stutter in intense game
so it created a need to bypass the conservative TDP limit .... a 3rd party freeware called Throttlestop .... specifically for tablets and laptop on intel cpu
stupidog
oic, but i dun play games.
need to get one mainly for design work and sometimes watch movies.
so which is better ?
the skull canyon or Shuttle SZ170R8 ?
if say i get Shuttle SZ170R8, where can i find service for installing the CPU & stuffs ?
Thanks.
Buaya_Hunter
Skull cayon is virtually a laptop that size of a set up box, just without a screen. Beside ram n hard disk/ssd, u can't change or upgrade anything.
The shuttle is a bigger small form factor pc with expansion slots, where u can install a graphic card if u like.
stupidog
ic.
meaning if take shuttle, i can upgrade my parts like cpu in future if i need kaby lake ?
intrance
ic.
If you like shuttle's small footprint.. i think you may like silverstone sugo series, such as sugo sg05 itx casing.. it has smaller footprint than the shuttle..
and the best part.. you can customised and DIY whatever parts you fancy..
intrance
True that but if going for custom build lots of other cases to choose from like coolermaster elite130 or fractal design core 500 etc which is not limited to the PSU used.
understand that.. but they have bigger footprint.. contarary to what TS want..
of course, if TS dont mind slightly bigger footprint.. there will be alot of choices.. such as you mentioned.
wwenze
Ask you a question
How many screens and peripheral are you going to use for your design work
And compared to those screens, how much space does a PC take up?
stupidog
Ask you a question
Jus 2 monitor. My desk already got 1 x wd thunderbolt drive, 1 x 2 hdd bay, 1 x keyboard, 1 x wacom tablet, 1 x laptop. So i dun think i can put a tower cpu beside my monitor mah.. That is why I need a small pc
Sent from Samsung SM-G935F using GAGT
stupidog
lol i think until head big big :s22:
was browsing the internet for shuttle sz170r8 v2
if i gonna assemble everything from scratch it gonna over my budget
sz170r8 v2 @ 629
512gb samsung 950 pro NVMe @ 519
i7-6700 cpu @ 500
2 x 8gb ram @ 110
gtx 1060 6gb G1 @ 478
total = 2,236 :s22:
