Hi everyone,
It has been awhile since I last built my own PC so a bit out of touch.
Preferred budget would be $1600 but can go up to $2000.
Intended uses of the PC:
(1) play FFXIV Stormblood and Overwatch on Max settings, 1080p and 60 FPS.
(2) May consider having a dual monitor setup to do work (MS word, Adobe Photoshop, Illustrator and InDesign) on one monitor and game on another but is not essential. Currently have Dell U2414H and Dell SE2717H monitors.
Looking at the PC themes pricelist, I was intending to get the following:
AMD Ryzen R5-1600 + MSI B350M Mortar | $478
Corsair LPX 2400Mhz 8GB x 2 | $199*
MSI GTX 1070 8GB Armor OC | $689**
Samsung EVO 850 250GB SSD | $159
Seagate 1TB Barracuda 7200RPM| $72
EVGA G3 Series 550W | $159***
Fractal Design Define C (with window) | $149****
Total: $1905
* PC Themes listed this under “AMD Ryzen DDR4 RAM”, is there a difference from other RAM?
** Not sure if MSI is good or others may be better. Actually, I was considering the MSI RX 580 8GB but I thought the GTX1070 is worth paying a bit more for the gain in performance?
*** Is this enough to power the entire system?
**** Prefer cases with a simple design and easy cable management.
Any suggestions/advice?
Thanks in advance!
Total: $1905
Thanks in advance!
