Need Advice for 2k Gaming Rig
ranseur
Hi brothers!
Need help before i hoot again
This time helping my brother to setup a gaming computer
(Budget 2k) For High end gaming , editing photos, 3D Maya
MB/Processor: MSI Z87-G45 Gaming (i7 4770) - $633
GPU: MSI 660ti ($483) or MSI 670 ($599): Cant decide which
RAM: Corsair Veng 1600 (4gb x 2) - $95
Display: Dell U2312HM - $255
HD: 1tb blue (WD) - $85
SSD: Crucial M500 120gb - $180
Casing: Fractal Design R4 Black - $149
PSU: FSP 550w - $139
WIndows 8 Home 64bit - $163
Total: $2298 (670) / $2182 (660ti)
Overshot by 300bucks =( any better bang of bucks with the same items?
As usual price from PC themes ;)
Any advice or input will be appreciated!
Cheers!:s12:
sdhdaniel
And better monitor. Lower the other parts so you will stay within budget and better monitor if can?
m3 th3 last
Go for MSI B87-G43 + i7 4770 $496
Tradepac selling MSI 770 GTX Lighting @660 if u want to consider
G-SKill is about $10 cheaper
Go for plextor M5 Pro @ $172
Go for Seasonic M12II 520W 5 yrs Warranty @ $99
Other shop selling $122
ranseur
nice
where do see the G43 baord selling at 496 ?
sdhdaniel
Case: FRACTAL DESIGN ARC MIDI R2
PSU: FSP 550W PLATINUM 80+
MOBO: B75A-G43 GAMING
CPU: i7-3770
RAM: CORSAIR VENGEANCE 1600mhz (2x4GB)
GPU: ZOTAC GTX 780
ODD: SAMSUNG DVD RW
HDD: WESTERN DIGITAL BLUE 1TB SATA3 64MB
SSD: PLEXTOR M5P 128GB
OS: WINDOWS 7 HOME PREMIUM
Monitor: ASUS MX239H
Maybe you can try this set up. I don't see a benefit for getting Haswell at the moment so yeah and windows 8 is optimized for touch screen monitors. With you budget don't think you can get one
speedsurfer
Are games now still having frame drops and problem running on Win8 ? Steam forum got a few people games cant play after they upgrade to Win8 from Win 7
eD1s0n
well I had some problem with my existing steam games after upgrading. But after re installing and/or troubleshooting then so far all manage to work
m3 th3 last
nice
Best Buy, but u can ask whatever shop u are buying from to match it.
Haswell, not point to overclock. The head generated is crazy even at default clock speed. Stock Cooler can hit 80 degree at load!!!
Not sure if it is even good for long-term usage at all.
"Z" series chipset is for overclocking but you need a CPU ending with a "K" so that is can be overclocked.
"H" series chipset is for home user.
"B" series chipset is for business user, who need a cheap and functional motherboard for office use.
Of course since there is hardly any difference between "H" & "B" series MB it all comes down to the price. Only "Z" series will stand out due to it's overclocking ability.
ranseur
n
Nice info thanks !
ranseur
so changing to haswell is not recommended ?
