Need advice for budget pc build.
leonistic
Hello! Quick check, have you gotten this yet ? Usually there won't be any pc building service fee if you purchase from them.
Tradepac should be ok. Same for PC Themes. Usually they will give the boxes and stuff back to you. 95% of the time at least. It depends really. You can always request for those to be retained and not thrown away anyway. Never really had such scenarios happened for me but saw it once when it happened to a friend of mine. Not those shops you mentioned tho. Shall not name it here..
Anyway, I can help you out actually if you have not purchased your com yet. Just PM and drop me a msg and we can work it out from there.
Cheers
neoslover
bro, if you search Carousell for GTX 1060 6gb version, can be as low as $300. GTX 1060 6gb is really good for 1080p gaming. GTX 1050TI not so
neoslover
For monitors, now tradepac having discount on their LG 24mk430, 24 inch IPS monitor with 75hz refresh rate for $145. My friend bought it and it's great. He uses it to play DOTA2, CSGO, no problem
