Need advice for building a new pc
powerballz
Hi everyone!
I am thinking of building a gaming pc with a budget of 1.5k. I will be using it to play games like BF4.
I browsed the forum and came up with a rough list of parts.
i5 4570 and ASRock B85 Killer
G Skill Rip Jaws-x 1600MHZ 8GB
Crucial M500 120 GB
Western D 1 TB Blue
Win 7
I am looking for something that will last for about 2-3 years before requiring an upgrade.
I do not need a monitor and ODD.
For the GPU I am currently looking at either GTX 760 or R9 280X.
1080p is preferred but not necessary.
Thanks! :)
EienShouko
Hi everyone!
Crucial M500 120 GB
Western D 1 TB Blue
Win 7
Thanks! :)
280X. No need to think if you're playing BF4.
Your other parts look good.
Grab a Superflower HX600W and a casing you like and you're good to go.
Jian19
i5-4570 + Asrock b85 killer ~ $357
Crucial 8gb ddr3 ~ $90
Plextor m6s 128gb ssd ~ $120
Wd blue 1tb ~ $74
Msi 280x gaming ~ $470
Seasonic g550 ~ $110
Fractal design arc midi r2 ~ $140
Win7 64 oem ~ $115
$1476 buy and DIY @ tradepac ask for discount. If not sure how to DIY can bring to gs shop ask him help u assemble @ a fee.
royfrosty
Hmm 1.5k
ASrock b85 Killer + i5-4570 ~ $357
Crucial 8gb 1600mhz ~ $89
WD Blue 1tb ~ $75
Crucial m500 120gb ~ $115
Powercolor r9 290 4gb ~ $619
Superflower hx600 600w 80+ gold semi modular psu ~ $108
Sharkoon BD28 ~ $77
Windows 7 Home premium 64bit oem ~ $110
Total ~ $1550. Buy at tradepac. DIY
If you really wanna keep within budget
ASrock b75m dgs + i5-3350p ~ $271
~ $1464. Buy at tradepac. DIY.
It is good to go for 290. Good stuffs that performs on par with 780. And for 1080p gaming, this card could give u max settings with good fps.
Yureak
Hmm 1.5k
WD Blue 1tb ~ $75
Sharkoon BD28 ~ $77
Roy is right if youre on a budget go for 290. Most bang for buck. If you want more performance though go for 780.
Also be mindful of the heat + reliability issues with this gen of AMD cards
powerballz
If I pick 290 will there be alot of heat issues?
If so, should I buy more fans or get a casing with good ventilation?
Thanks for the advice so far, appreciate it!
Yureak
it wont so much affect other component but your card will throttle alot probably unless you get a good custom cooler and even so ive heard theres a reason ppl go full waterblocks
royfrosty
Its fine lah -.-
The heat output on a single card with a custom cooler design is rated around 84deg. Wont hit 94 unless you have crossfire it.
Else a single card is fine.
A ATX chassis is fine with adequate amount of fans will go fine. As long as got air exhaust out is fine.
290 wont throttle if its on a single card playing game. Not unless you put 2 inside then may have an issue.
powerballz
Haha sorry I tend to worry too much.
Thanks for the advice, I have a solid idea with my build now!
Jian19
Can consider sapphire tri-x 290 if u wan to get 290 card..
royfrosty
Yes this card also can get. Just take note of the 2 years warranty only.
But for a newly redesign heatsink i would not mind.
Yureak
well if roy says it wont throttle on non-ref coolers then i guess good
AMD cards are designed to operate at much higher temps
My 780 throttles at around 75 or so with artifacting i have to bring it under 70
MoneyFace =p
CPU+MB: Intel Core i5-4440 + ASRock B85 Fatal1ty Killer @ $345
RAM: G.Skill RipJaws-X DDR3-1866 CL10 8GB Dual Channel Kit [Red] @ $115
GPU: PowerColor R9-280X 3GB TurboDuo @ $435 (Cybermind)
SSD: Crucial M500 240GB @ $175 (t258jgn)
HDD: Western Digital Blue 1TB @ $72
PSU: Seasonic S12G 550W [80 Plus Gold] @ $100
CASE: Fractal Design Arc Midi R2 @ $139
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $1496
Buy others from Tradepac, #05-18.
_____________________________________________________
Or if you wish to squeeze in a R9-290...
CPU+MB: Intel Core i5-3350P + ASRock B75M-DGS @ $271
GPU: PowerColor R9-290 4GB @ $549 (Cybermind)
PSU: Super Flowr Golden Green 600W [80 Plus Gold] @ $108
CASE: Corsair Carbide SPEC-02 @ $79
Total: $1484
Both are still red and black themed! :s12:
