Need advice for PC build
katsu88
Need advice for the build below. I usually do some light gaming watching show surfing website with 10 tabs or more.
CPU: AMD Ryzen 7 7800X3D
MB: Asus Rog Strix B850-F Gaming Wifi
GPU: Zotac RTX 5070Ti SOLID
RAM: ADATA XPG LANCER Blade RGB 6000MHZ CL 30 64GB
SSD: SSD: WD Black SN850X 1TB
PSU: Superflower LEADEX VI Platinum PRO 850W
Case: Casing: NZXT H6 Flow (black)
Cooler: Thermalright Phantom Spirit 120 SE
ignies
budget? monitor resolution?
what games do you play? this would be more than enough for light gaming, should be able to handle most games at 1440p and even 4k with dlss.
katsu88
Budget around 3.5k. over is fine as well.
Monitor resolution: 3440x1440, using 34 inch monitor.
Games like CS, Dota 2.
ignies
for CS and Dota 2, your specs given is more than enough and should be able to handle your use case no issues.
how much were u quoted/is your current build at now?
NightRaven49
general use + light gaming dont require a 5070ti, especially when its still overpriced at the moment. 78x3d makes more sense for these games since modern gpus have no issue spitting out hundreds of fps in those titles, but also somewhat overkill. 64gb of ram is also a lot for this use case, unless ur already maxing out 32gb (which is very unlikely for gaming + web surfing). i suggest u just go for 32gb ram and drop the gpu to a 5060ti 16gb/7800xt which cost much less for basically the same user experience, overall build should cost only about half ur budget.
soreloser
Imo your build is completely overkill, 5070/5060ti is more than enough for your games. 32GB RAM and a regular b850 board will probably save u $1000, you don't need 64gb ram for 10 chrome tabs + game open.
GotBetrayed
Probably don’t even need 7800x3d. 7600/7700 will do.
7600 + 5060ti +32gb ram enough. Actually 1.5k sufficient
katsu88
Thanks for the advice.
GotBetrayed
indeed..i got a 7600 with b650 and 32gb ram
game and chrome ....very smooth
Ya I had a B650M, 32 Gb ram, 4070ti and 7600 also run pretty smooth. Much cheaper also lol compared to my 5080 + 9800X3D.
GotBetrayed
invader Pc got 7700 and 5070 for 1566. Seems like a decent deal with Asus TUF b650M-E motherboard
katsu88
hey bro have u decided? Looking at similar build too and only play cs2 🤣🤣🤣
In the end I went for the build below. I know it’s overkill but since I had the budget I just go ahead 🤣
SSD: SSD: Lexar NM790 2TB M.2
Fan: ARCTIC P12 PWM PST ARGB BLACK - Qty 4
ARCTIC P14 PWM PST ARGB BLACK - 6 YRS Qty 2
Total damage: $3640
m0n0n0ke
Total damage: $3640
For that price only 5070?
GotBetrayed
Total damage: $3640
I paid around 3635 with Zotac 5080, 9800x3d, Aorus elite ice b850M wifi board.
4tb Samsung 990 pro ssd.
32 gb patriot 6400mhz ram.
also includes windows 11 license.
Thermal right 360 cpu cooler.
you sure the shop not trying to carrot you?
I bought my pc from aftershock btw
Vanyel
Pls let us know which shop so that everyone else can avoid
below i just locally searched for agar agar pricing, didnt even want to see taobao how much
u ownself decide how much they chop u ba
they charged u 2k for 5070ti is it? :mad:
and all these system builders should have a better pricing than us diy
MB: Asus Rog Strix B850-F Gaming Wifi - $866+ (cpu&board)
RAM: ADATA XPG LANCER Blade RGB 6000MHZ CL 30 64GB - $320+
SSD: SSD: WD Black SN850X 1TB - $115+
PSU: Superflower LEADEX VI Platinum PRO 850W - $146+
Case: Casing: NZXT H6 Flow (black) - $159+
Cooler: Thermalright Phantom Spirit 120 SE - $59+
