Need advice for PC build
kiatme
Need some advice for some simple light gaming, budget around $2000
CPU : AMD Ryzen 5 7600
MB : Asrock B650 Lightning + Wifi
GPU : PULSE AMD Radeon RX 7800 XT 16GB
RAM : Corsair Vengeance RGB DDR 5 6000MZ CL36 (2x16GB)
SSD : Crucial T500 Pro Pcie Gen5 Nvme m.2
Cooler : Thermalright phantom spirit 120 se0
Casing : iCUE 4000D RGB AIRFLOW Mid-Tower Case, Black
PSU : Corsair Rm750e 750watts 80+ gold
Appreciate all comments thank you!
m0n0n0ke
looks great
i have a similar set up too
just that i am using rtx 2060
NightRaven49
this set up is more than enough for light gaming, shouldnt cost u more than 1.6k if u diy, prebuilt can find for even cheaper. i would go for lower cl memory (ideally cl30 or less) and a better psu.
soreloser
can save some money with 7600 + ps120 se from taobao. At minimum get the ps120 se from taobao, same as the one we get locally but cheaper by $20. Personally i like 5060ti 16GB over the 7800xt, but thats cause i like DLSS4. 7800XT is slightly better than 5060ti but no upscaling at all, so in the event that you ever need upscaling or any features, you are missing out.
-Synchronicity-
If can wait, wait for rx 9060 xt release. Might be what u want.
Probably will be announced during computex later this month.
yusoffb01
get 7700 from aliexpress, less than $300. or 9600x is $250
get 64gb ram. when i had 7800xt, 32gb is used for shared vram.
light gaming should consider 5060ti 16gb. It is 20% slower than 7800xt at 1440p, but ai performance is more than 2x faster.
limk0pi83
which psu would u recommend?
