Need advice from gurus
infusionist
Thumbs up advice needed from gurus
Can i ask tech gurus for opinions as I am looking to getting 2 monitors. 1 for gaming and another maybe just normal surfing net or watching movies.
Was thinking of either 2 x PRISM+ X315 PRO 31.5 or Samsung C32HG70 x 2. Happy for any other type of recommendations.
Or is there such a setting of getting a gaming monitor X315 Pro and another PRISM+ X315 MAX since that is 4k and not for gaming as gaming requires fast response rates. (hope i'm right on this). Are they able to even work together concurrently?
basic computer specs are RTX 2080Ti x 2 and i9-9900X
Thanks gurus.:s13:
Swiftbladez
Yes will work. but putting different monitors side by side might be uncomfortable for OCD people. practicality wise works, aesthetic wise YMMV
Bardiel
x315 max is 4k but 60 hz
x315 pro is 2k but 144 hz.
so depend on what u want. it will be weird if 1 is 144 and the other is 60 hz. 2k vs 4k too.
infusionist
Thanks for the advice Bardiel. Totally know what you mean. Considering i'm using 1 monitor for gaming and another for movies/youtube/net surfing, would that be a good setup?
On top of this, i read that the Asus gaming monitors are the bomb compared to Prism+, slightly pricier.
Naoyuki
Looking at your rig, pretty sure you dont have any budget constraints and i think you should just go for the Asus ones imo.
yuseiyow
Since you using x315 max 4k 60 hz for work and x315 pro 2k 144 hz for gaming, it can help you stay productive :o
You will be more inclined to do your work on your higher resolution monitor.
The 2k gaming monitor will be a godsend once you play games taking advantage of its high refresh rate.
:s12::o
