Need advice on 2nd hand CPU
east_dweller
Hi all, need some Guru advise on the following CPU set-up.
Has been using laptop for a while and totally lost touch with all the computer parts.
Currently I have an overseas client leaving Singapore and selling his CPU (with existing parts warranty) for the following parts below for $700.
Can anyone advise it is worth buying it or to assemble a brand new CPU with a budget of max $1K? Wanted a PC for gamings and work. Thanks in advance!
I7 - 9300 (2.8Ghz)
4G Ram
Ge Force GTX 285
Asus Sabertooth X58MB
Cougar R5 558 PSU
Razor keyboard
1TB HDD
IdunoWor
I7 - 9300 (2.8Ghz)
4G Ram
Ge Force GTX 285
Cougar R5 558 PSU
Razor keyboard
1TB HDD
I think it don't worth $700 for it
shadow84
A lousy psu which may break anytime, used-to-be high end CPU and mobo, all not worth it...
if you got 1k, can build frm scratch, wif parts much better than that list...
MoneyFace =p
Nope $700 will get you something equally powerful but sips energy, unless he's throwing in his copy of Windows (assuming it is legitimate) as well.
Jian19
1k get a new one better..
I5-3470 + Asrock b75m-dgs ~ $292
Kingston 8gb ddr3 ~ $90
Wd blue 500gb ~ $60
Palit gtx760 + fsp raider 550w ~ $399 or Msi 7850 tf 2gb + fsp raider 550w ~ $318
Samsung 24x DVD drive ~ $21
Sharkoon ms140 ~ $52
Win 7 64 oem ~ $115
Total $1029 for gtx760 or $948 for 7850 ~ buy and assemble @ tradepac , ask for discount ~
east_dweller
Wd blue 500gb ~ $60
Win 7 64 oem ~ $115
Thanks for the responsive advise.
From the price quoted above, does it includes the casing as well? anything that i should add like cooling system or not listed in the list above?
Just wanted to have a better estimate and consideration that whether should I stretch my budget if needed to....
east_dweller
Sorry what do you mean sips energy? assuming its an original copy of Windows, is the specs good enough? afterall its a 1.5 year old CPU. Thanks!
royfrosty
For 1k
Asrock B75m dgs + i5-3350P ~ $271
Kingston Value Ram 8gb ~ $90
Hitachi 500gb ~ $60
Sharkoon MS140 ~ $52
Palit GTX760 2gb + FSP Raider 550w Silver ~ $399
Samsung ODD ~ $21
Windows 7 Home Premium OEM 64Bit ~ $115
Total $1008 Buy at tradepac DIY
No need till 3470 if you feel is over your budget. A i5 3350P will do the same job. Lesser power consumed and same speed. The only thing is no onboard graphics. But since you get the standalone GPU it doesnt really matters.
east_dweller
Seems like the parts recommended is almost the same as the other member. In your opinion, should I sketch my budget for better graphics, speed or other aspects? doesn't want to upgrade my CPU very often. Thanks.
For 1k
Hitachi 500gb ~ $60
Samsung ODD ~ $21
tony_ong
like wat the other bros suggested go for new system.
what type of game u playing?
east_dweller
Any particular brand of casing of cooling system recommended too? Basically i prefer something not too big and stylish for casing. Thanks all for the fast advise!!
east_dweller
Haven't been gaming for a while. Used to enjoy playing games like Dota, Counterstrike, Starcraft etc. Looking to play League of Legends, Diablo II etc.....
Jian19
If u are not overclocking normal casing and stock hsf is good enough for u
For the games u play gtx760 or 7850 can max out easily..
As for casing u can consider
Fractal design Arc Midi ~ $139
Corsair 350D ~ $149
Nzxt phantom 410 ~ $155
Sharkoon t28 ~ $89
Asgard pro ~ $79
royfrosty
Another one you might be interested is the NZXT 230 white or black $109. Very silent case and yet very sleek.
east_dweller
Corsair 350D ~ $149
Sharkoon t28 ~ $89
Asgard pro ~ $79
Thanks so should I get a better graphic card? for casing where should I shop at?
Jian19
U can walk walk see see and check the cheapest price, then ask the shop where u buy ur other stuffs whether they will match the price..
royfrosty
Corsair 350D ~ $149
Sharkoon t28 ~ $89
Asgard pro ~ $79
Among this 5 chassis. The best cooling options for matx is the 350D. It has a 2 120mm top mounting fan for exhaust.
Nzxt phantom 410 is the worse plastic made chassis ever. Almost no wire management. So the h230 would be a better option.
The best valued one will be sharkoon t28. Comes with 3 120mm led fans.
FD arc midi is more of a premium metal brush paint finishing.
east_dweller
How about Coolmaster?
