Need advice on Graphic Card
NetWeight: 15g
I'm currently running on:
CPU: i3-4150 3.5ghZ
MOBO: ASROCK H81M-HDS
GFX: AMD Radeon HD 5700 Series
Thinking of upgrading to MSI GTX 960 Gaming 2GB card.
Question is:
If i were to run a graphically demanding game (let's say witcher 3) and my CPU were to bottle necked, would my system still be able to fully utilize GTX 960 capabilities?
If so, which GPU would would you recommend.
Thank you.
kaixax555
CPU: i3-4150 3.5ghZ
Question is:
Thank you.
GTX960 should be fine IMO
Jian19
its fine
msi gtx960 armor oc will be decent, if using small case maybe asus strix or gigabyte itx
Goodshot
Ur cpu can play , but gtx960 cannot . witch3 are graphics intense , at least a r9 280x onwards
Jian19
AMD card is lol for w3
like dun bother...minimum get a gtx960 its fine ~
Goodshot
Very easy to see one , brand new can play high setting game card = $480 above , used $250 above . lower than that cmi
