Need advice on making mini ITX powerhouse!
alliarnette
Hi HWZ!
I've been planning to make a mini ITX PC for my living room which has a 55-inch TV that I want to use on.
I plan to play games like Counter Strike: Global Offensive, Crysis 3, Guild Wars 2, Civilization: Beyond Earth, League of Legends and Dota 2 as well as many other Steam games on this PC with as good a resolution I can probably get.
My budget is around $1500 to $2000, although a $200 overhead is still possible.
All I've decided on so far is that I'll be looking for a Fractal Design Node 304 casing.
I won't need stuff like CD drives (I have a USB reader), keyboards, mice, or monitors. Ideally I'd like this PC to be as compatible as possible for games in the future, because I plan to use this PC for a long time to come.
Thank you for your help!
alliarnette
anyone?? :(
I do not have a set deadline for when I am getting the parts. Should I wait for Skylake??
DarkBlue
anyone?? :(
Skylake is after mid-2015. I think you should wait because next jump is 14nm consume less power and runs cooler.
Smaller "nm" manufacturing process is always welcome.
alliarnette
State display resolution of TV. If dunno, state exact model of TV instead.
I believe it's Full HD. Although have plans to upgrade to 4K when the price drops.
And I see, I think I can wait until mid 2015. For now I'm still using my PS3/4 and Starhub box, but I plan to move over to using the PC only for the TV.
But for the graphics card and the rest of the parts, all should be hoot later hoot cheaper, right? But what kind of graphics card is needed to power the graphics for the TV? Plan to use it to play games and stream from Twitch, will 4K put way more stress on the processing power?
Thank you for the reply!
EDIT: Checked, yes it's FHD.
Alternative X
1080p not very hard to power, a GTX 970 should do for your games. 4K resolutions are a different thing altogether. To run games at 4K, you are going to need at least SLIed GTX 970s for playable performance. Would be better to avoid 4K gaming for now, SLI/Crossfire setups are only possible in a ITX format if you brought GPUs like the Titan Z or the R9 295X2 for SLI/Crossfire performance in a GPU and these things costs a bomb.
Would be a good idea to wait for AMD to release the R9/7 3XX GPUs before deciding your build. Would also be interesting to see what Nvidia will do in response.
