Need advice on PC built
Jian19
I5-3350p + Asrock b75m dgs ~ $271
Kingston 8gb value ram ~ $90
Wd blue 1tb ~ $80
PC 7850 2gb ~ $233
Seasonic s12 520w ~ $78
Nzxt h230 ~ $105
Win7 64 oem ~ $115
Total ~ $972 buy and DIY @ tradepac
triggerkappyy
Wd blue 1tb ~ $80
PC 7850 2gb ~ $233
Nzxt h230 ~ $105
Win7 64 oem ~ $115
Appreciate the fast reply
royfrosty
Asrock b75m dgs + i5-3350p ~ $271
Kingston value ram 8gb 1600mhz ~ $93
WD blue 1tb ~ $80
Palit gtx760 2gb + superflower hx500 golden green 80+ gold efficiency ~ $399
Sharkoon ms140 ~ $52
Windows 7 home premium OEM 64bit ~ $115
Total $1010 buy at tradepac. Diy. Bargain to meet your budget.
Not sure what is your fps games you play. But if you intend to play battlefield 4 I would highly suggest an gtx760 or r9 280/7950 equivalent to enjoy at max settings.
triggerkappyy
a PM from a forumer*with thanks
Intel i5-4570 3.2Ghz
Asrock H87M-PRO4
ADATA 1600C11 8GB
Seagate 1TB 7200rpm
Leadtek GTX760 2GB OC
LiteOn 24X DVD-RW
FSP Raider 650W
Coolermaster N200
juz to share
