Need advice on power plug
wolnavi
Hi, I bought the Xiaomi handheld vacuum cleaner from Taobao and the power adapter they provided is a China plug understandably, so I used a international adapter:
But when trying to plug it in, it is loose:
Is this safe? If not, what can I do about it? It is brand new...
alamakazim
U can widen the 2 pins.. then the fit is better
But it might break... Cos cheapo stuff
wolnavi
Force lo...
Or a better adapter
Or replace the 2 pin plug... Cut and replace 3pin
Force scared later break šŸ˜…
How to cut and replace? If find a better adapter, is it must match the input/output as stated in the original plug?
Thanks
hellspawn_one
it is not ideal, but yes it still can be used. Just that a slight pull, the plug might falls off and no power lor...
Koenig168
How to cut and replace? ....
Thanks
NO! :eek:
The plug is an AC to DC plug. If you replace with a standard 3 pin, you will be feeding 240V instead of 30V to the vacuum cleaner.
wolnavi
It won’t catch/cause fire and/or sparks right? Don’t wanna cause a fire šŸ˜…
just use la.. the most only catches fire lor...
cheap products is liddat one.
Scared later whole house on fire hahaha
NO! :eek:
Ooohhh I see
hellspawn_one
Ooohhh I see
no, it won't cause a fire... no spark also, just not nice looking. It is a charger only, so you won't be moving it around anyway.
kandinsky
You can buy better quality adapters, those will be a more secure fit. I usually get Taiyo, from challenger. $3-4+ I think. Looks something like this:
shadey
Duct tape.
But still, why are we talking about vacuum cleaners in the Hardware Clinic???
