Need advice regarding RAM for Ryzen
Alexls
I bought a 2200g with msi b350m gaming mobo, gpu is rx570
Is 2x8gb gskill ripjaws v 3000 ram overkill for this system? Bought the ram yesterday then today realise it seems way too high end for such a budget cpu and gpu.
Should i change it 2x4gb 2666? Or what other ram?
-Grift-
More intrigued on why you bought a APU + Dedicated GPU
Ryzen scales well to about 3000Mhz so I would recommend you keep it.
wwenze
Because they don't sell 4 cores without APU, and it's cheap.
Plus it works as a backup so why not.
From Cybermind:
Cheapest 2200g bundle: $255
Cheapest 8100 bundle: $320
Of course there is total cost of system vs total performance to consider also...
Alexls
2200g rx570 performance quite good for 1080p gaming
2200g 125-30=95
b350m gigabyte gaming 83-30=53
total 148 only
the cost of the ram 158-30=128
almost the same as the cpu combo:eek:
