Need advice, upgrade or overhaul?
Gilch2
Hi guys, need some advice. If I wanna upgrade my rig? Should I do a complete overhaul (new mobo, cpu, gfx card, ram, PSU, casing)?
Any specs suggestions for a $1.5-2k budget? (assembles at shop).
Mainly use for gaming (BF1, Titanfall2, Dishonored 2, etc) on high settings. Will be using back same samsung monitor.
Current setup
AMD Radeon R9 200 Series
8gb ram
Intel i-4570 CPU@3.2ghz
Windows 7 (64bit)
Thanks alot for help!
MianBaoFren
ZrE0_Cha0s
well i still think that u should tahan till next year feb and maybe get amd zen or intel kabylake.
MianBaoFren
or he can simply tong buy a good gpu first to add on to the new series of cpu next year. i dun see much bottleneck in his rig really.
straweffigy
I think just upgrade GPU to GTX1060 3GB version, will be good for quite awhile.
ragnarok95
Senior Moderator
Senior Moderator
Get a SSD. Get either a 1050Ti or a 1060 and you are set to go.
Save the rest of the money.
