need advice with Razer deathadder transform invisible snake..
mozaat
My rig... sigh.
Was trying to uninstall razer mouse driver as brought a new g17 mouse but in the end now device manager cannot detect either mouse at all.
When reboot to cmos both mouse can use but when boot into win 7 os, the mouse cursor will fly to near start button and dun move anymore. Using keyboard only and check device manager can see usb conflict. Tried install uninstall driver but nothing works. When rebooting i go into cmos mouse can move.
Any guru here be able to repair or troubleshoot ? if can let me know ur repair fees also thx
Moz
Pm me potential guru
9667716seven
localITguy
Suspended
My rig... sigh.
Moz
9667716seven
boot into safe mode and uninstall the driver,
would advise you to remove your no.
mozaat
Thx for reply!
Tried in safe mode mouse not working only razer keyboard.
Razer keyboard, razor mouse..driving me crazy.
Has already been 18hours gone without gaming. Suffering from very bad withdrawal..
Save me Guru! !!!
mozaat
Sec.
Uninstall all Razer driver in safe mode and reboot ?
Earlier not in safe mode i uninstall all mouse driver also then more stuck as device manager doesn't show the mice entry.
Koenig168
You can try using Win 7 system restore to undo the changes.
grimfan
Try using the program below to remove all mouse related HIDs (Hardware Input Device/s) and/or duplicates. You should also be able to do so in Safe Mode if you can't can it done without using your mouse in normal startup.
http://www.nirsoft.net/utils/usb_devices_view.html
After you do so, maybe you can try plugging in your new mouse and let it install normally again.
Hope this helps.
