Need advise for home computer
deepblue_82
CPU+MB: Intel Celeron G1820 + ASRock H81M-HDS @ $116
RAM: Crucial DDR3-1600 CL11 4GB @ $45
HDD: WD Black 500GB @ $73
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE+PSU: In Win BK644 + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $103
$30 wifi card
Total= $388 from TP.
enough for youtube 1080p
nice cheap rig.. no ssd got black hdd..
bagger 288
Suspended
Ark Law
woah thanks for build. Which processor is faster? should be the G3220 correct?
Yes. G3220 is faster. And ZBox ID18 MiniPC processor slower (Ultrabook Celeron, not Desktop Celeron). For normal usage, Pentium paired with SSD is important, cause it means OS operation is smooth and the bottleneck is now the processor.
If you've got extra change to spare, do consider upgrading the PSU to Seasonic S12 520W at ~$84. Overall a more solid and all-rounded PSU with a 5-yr warranty. Even in the very unlikely event it goes bang, can just bring to Corbell and get it exchanged straightaway.
Beepok
CPU + Mobo: Biostar H81MHV3 + Pentium G3220 - $126
RAM: ADATA 4GB 1600MHz - $49
SSD: Plextor M6S 128GB - $104
PSU: FSP 300W OEM - $39
Casing: Generic ATX casing (Headway, Vios etc.) - $20
Wifi: TP-Link WN722N USB - $26
Usually fuwell etc they charge more if I buy using credit card right? Any shop doesnt do this? And is there a 350w seasonic psu? 500w a bit overkill
Ark Law
All shops will charge sextra for CC. NETS depend, some like TP don't, some like PCT do.
That's the lowest retail Seasonic, I don't see OEM units lying around. FSP is the only one ($39 but 1-yr only). Generally FSP Seasonic and Delta PSUs are of "safe & OK" standard.
deepblue_82
u can try pct or trade pac..
350w i dont know got good one anot..
Beepok
Ark Law
how about i just reuse my psu?
If that PSU chibabom and take out all your other components, only got yourself to blame. Quality costs money.
"The power supply unit in a (powerful) computer should never be neglected." -Maeda_Toshiie
deepblue_82
both of the brand not that bad.. but u might have to take the risk if u wan to use back them...
Ark Law
Use the one which still has warranty. If both bo, I'd personally use FSP because they're the larger OEM. I myself have a spare OEM FSP
Beepok
think the systems are 10 or more years old le, no warranty
