no choice need to use has to replace
was considering getting this cheaper mic one $187 but has doubt about the warranty
https://shopee.sg/Maxby-MAX7200-NVM...50?xptdk=199faa6e-e154-47c0-8911-b6d57c622ad4
I would advice not to buy China SSD like this unlike the one Zhitai E7.
Zhitai E7 uses YMTC NAND which is also found in SSD like Lexar.
Should OK to use.
But Gen 4 SSD key issue will be heat make sure the SSD is not running hot.
Especially if your motherboard has no M.2 SSD shield to keep it cool.
As SSD prices is at all time high, options are very limited especially for budget.
Only options are either Lexar or China SSD like this.
I don't have much knowledge or experience with China SSD.
But those from Aliexpress usually best avoid as high failure rate.
