darkcalibur
- Aug 31, 2005
Hi all, first time building a PC from scratch. I have done an extensive research on all the components, mixing and matching parts and try to get the most bang for buck components for the limited budget that i have. Would be nice to get some advice and feedback from you guys.
[CPU + Mobo] Intel i7-6800k + ASUS X99-A II / USB3.1
[GPU] ASUS GTX1070 8GB Strix
[RAM] Corsair Vengeance LPX 32GB (4x 8GB) DDR4 2666MHz CL16 Quad Channel (Black)
[SSD] Samsung EVO 960 512GB SSD (when available hopefully by late Oct)
[HDD] HGST Deskstar NAS 4TB
[PSU] Superflower Leadex Gold 750W F.Mod
[CPU Cooler] Cryorig R1 Ultimate Cooler
[ODD] ASUS 24x DVD-RW SATA OEM
[OS] Windows 10 Pro
[Monitor] Dell UltraSharp U2515H 25" IPS LED (x2)
[Casing] Cooler Master MasterCase Pro 5 Mid Tower
[Casing Fan] Noctua NF-P14s redux-1200 PWM (x3)
[Headphone] Audio Technica ATH-M40X / Audio Technica ATH-M50X (undecided yet)
[Speaker] PreSonus Eris E4.5
[Sound Card] Asus Xonar U7 7.1 USB Sound Card
*I already have the OS and Monitors, planning to get most of the remaining parts from PC Themes, and elsewhere/online for parts that PC Themes does not have.
Purpose of this build:
I also intend to launch multiple programs concurrently, e.g. open Unity, Maya, Photoshop/Illustrator at the same time, and they should still run normally without any lag.
I am also not sure if I should replace the stock fans on the MasterCase Pro 5 with the Noctua fans, are the stock fans good enough for cooling? Noise is not the highest priority for me, although it should not make loud noises that are comparable to jet engines during normal operation.
I would appreciate any advise on whether my build is optimal for what I intend to do, and any replacements for these parts if necessary/advised.
Thanks a lot guys
[OS] Windows 10 Pro
- Mobile game development and programming with Unity
- 3D modelling, animation and rendering with Maya/3ds Max
- Graphic design and creation with Adobe Photoshop and Illustrator
- Video creation and rendering, sound editing, motion graphics/VFX creation with Adobe Premier Pro and After Effects
- Gaming mostly single player or non extremely competitive games (1440p, 60fps, High/Ultra settings)
- Web design and development with Adobe Dreamweaver
Thanks a lot guys
