(Need Help) $1000 pc build
jonnieboy
I'm totally noob at this so I need help here.
Can someone recommend me a $1000 pc build?
Dont need monitor, keyboard and mouse.
Wanna play games like pubg and mostly fps games.
Thanks!
Sent from Pixelated Boy using GAGT
Psycovirus
For your budget, best bet would be a Ryzen APU. If you could increase a bit more, then we can try fit a GPU...
I am unsure of GPU market at this moment though...
Sent from OnePlus ONEPLUS A3000 using GAGT
ItsmeagainhK
Thanks!
I think for pubg in low settings, you can go for gtx 1060. Anyway, gpu prices are sky high now. Would easily take up more than half of the budget if you are going for higher end cards.
Masaaki14
Build with a Ryzen 2200g or 1200, whichever is cheaper, 8 gigs of ram and probably a cx450/Masterwatt 550. Search through carousell or hwz marketplace for a 970 or a 1060 3gb, maybe a 980 if you're lucky for around 300-350. There's a listing for a Palit 970 for 280 right now in the marketplace
If you're free tmr evening I'm heading down to sls to check prices to finalize my build
thepasarmalamshop
Just Build this last week
MSI B350i Pro AC ITX + Ryzen 5 2400g + Corsair 3200 2 x 8G - $725
InWin Chopin - $125 (You can save more here if u dont mind bigger casing)
SSD Transcend SSD220S 240GB - $75 (Lazada Promotion)
Total $925
tmfwy
Thanks!
For $1000
Carousell / SLS...etc
I3-8100
8gb
GTX1050TI
OR get a glass cannon
G4560 + 1060 build. :)
Forget the Ryzen APUs. They are meant, ONLY for esports games OTHER than PUBG if not mated to a dedicated GPU.
Alot of people look down on the G4560 but truth be told. Its high clock speeds actually make it a very viable gaming option for FPS games
PUBG runs smooth on a GTX1050TI and a G4560
For really tight budgets, G4560 + 1050.
Have tested the above and rate it PUBG viable. :)
Masaaki14
For $1000
I3-8100
8gb
GTX1050TI
That is if, and only if, you play on the apu. The Ryzen 2200g is still a very capable cpu even if you use a dedicated graphics card. It's right in between the 8100 and g4560, both in performance and price.
Why I recommend the 2200g is due to the motherboard compatibility. Amd has promised that the current am4 motherboards will be used till 2020, when there's another batch of new cpus coming,meaning that if you want to upgrade later, you can get a newer cpu than if you decide to go Intel and need to replace the motherboard as well.
jonnieboy
Hmm thanks bro. I think I'll save up more first to get better specs.
tmfwy
Good points but imo, upgrading is a myth
More and more people are buying computers with a console mentality. One shot pain, throw away and buy new one after a looong time.
If you are talking about resale value
You lose more in the resale market than the cost of the motherboard when it comes time to sell. Compared to the intel counterparts, AMD attracts enthusiasts more than the casual gamers. The former knows the market prices better than the latter.
Performance wise the 2200G sits right in between the G4560 and I3-8100
But for $10-20 more, you get 10% higher performance with higher resale value in the I3-8100 + Motherboard
So the 2200G is relegated to one market which it excels in far better than any intel CPUs
That of the Cheapo Esports games EXCEPT PUBG AND as a work computer
I am actually using the R3-2200G as a work computer in a Chopin and i would say i LOVE it. It can playback videos, the occasional game or two, all on a 65W TDP. OCcasional edits. But most imortantly,. the Chopin doesn't feel Cheap. It doesn't look plasticky and it screams PREMIUM. vImportant if it is sited directly in front of one's eyes..
It is capable of playing CSGO Dota2 LOL Overwatch and most importantly Fortnite.
The difference between the 2400G and the 2200G is that that the 2400G is capable of handling epic fights in overwatch better than the 2200G ( which can transform to close to a 2400G with a $50 upgrade to a better cooler )
But at $100 more than the 2200G
It will find a tough match as compared to even a G4560 + GTX 1050 Combo which is $50 more than the 2400G
So i would say that if one needs a real cheap computer
2200G 8gb ram cannot be beat. You can get one for about $600 on carousell / SLS.
Add a monitor $140 and keyboard mouse and mousepad and it still costs less than $800. And if you want a ridiculously sized PC that you can carry to lanparties oh so easily, stick it in the Chopin for about about $800+/-
But for $1000
i3-8100 + GTX1050TI
or
G4560 + GTX1060
are good choices
gld998
If use apu for gaming means buyer on budget. Everytime wanna upgrade cpu?! Cpu not cheap ok!
Sent from Old Man Pressing For Retirement using GAGT
ahwei91
some pc system at tradepac looks not bad leh....
intel i3 8100
msi z370 gaming plus
8gb ddr4 2400
1tb hdd
sata writer
gtx 1060 3gb ddr5
tecware edge casing
fsp 600w psu
free kb and mouse
ssd 120gb (optional add $75)
total $1015 (excluding ssd)
Omfgitzmark
This one does looks good for the price.. :s7:
intel i3 8100
8gb ddr4 2400
1tb hdd
sata writer
gtx 1060 3gb ddr5
tecware edge casing
fsp 600w psu
free kb and mouse
Psycovirus
From Bizgram, SLS #05-50
  • CPU + MB: Intel i3-8100 + Gigabyte H310M S2P - $275
  • RAM: Klevv DDR4 2400Mhz 2 Ch 2*4gb - $121
  • GPU: Palit GTX 1050 Ti StormX - $278
  • SSD: Samsung 850 EVO 256GB - $125
  • PSU: FSP Hyper K 500W - $64
  • Case: Tecware Nexus M - $59
  • Accessories: Nil
Total Damage : $922
