Need Help and Advice
Onemxonly
I'm trying to build my own customized Gaming Pc
This is all the part i plan to have in my PC
1.Intel i7-6700K ( 8M Cache, up to 4.20 ghz )
2.Asus Maximus Viii Ranger ATX Z170
3.Cooler Master COSMOS SE case
4.Strix GTX 980 Ti 6GB GDDR5 (NOT OC)
5.Hyper 212X ( CPU cooler )
6.V1000 ( Cooler Master power supply )
Isit possible with $3000+ budget? Or is there a better setup i can get with $3000+. This is my first time customizing. And i wanted to know can i get some of this part in Singapore or not. Please give me some advice! Thanks!
jedi5diah
state your gaming "goal"
1080p or 1440p
3K is very easy without monitor
FlushX
With your budget, I'd recommend an AIO for cleaner look. There's no need to get 6700k unless you're doing CPU intensive stuff.
Can also consider NVME SSD if budget permits.
lcheowl
You can use my rigs as example ----------->
gld998
why skylake? Wait abit like a few month can get skylake-e? :D
