Need Help! and mobo replacement
acupofmilo
Hi,
My pc will just power off and power on sometime when i am using it i suspect is mobo issue, u guys got any cheap mobo to recommend? using I5-2500k nw\
thanks!
hengheng220
Hi,
thanks!
when it power off and on does it have blue screen or anything?
acupofmilo
like watch video halfway the screen just turn off like unplug power and than after few sec it will power on again.
royfrosty
Check a few things.
Take note when it goes blank. Does your chassis fan still spinning? Does your mobo CPU fan still spinning? Or does it totally everything blackout?
GPU overheating should be Screen black out. GPU fan may still be moving. But all the other CPU fans and chassis fan should be moving.
If it is the CPU overheating, then most probably all turned off.
Use HWMonitor also to take a look at the temps for both.
Use Prime95 to do a small stress test for the CPU.
If it shuts down then probably CPU overheated.
Use Furmark to stress test on GPU see what happen.
acupofmilo
Check a few things.
the temperature after using for 5hours+ w/o any shutdown with game running in background
mostly the shutdown happen during the first 1h of using after that it wont shutdown so far
royfrosty
Hmm. Gaming and all no issues?
But from the pic, 48min 48max is like impossible leh?
That one idle or on load?
royfrosty
Hmm 1st hour only. Then i think possible that the mobo or the PSU issues already.
royfrosty
Got to look at SLS now.
Cause from what i know their stocks for Sandy/Ivy boards are reduced a lot.
Got to check on B75 chipset or something. But no overclocking. Got to see your budget also.
thegamer1907
The game running in background, but not in active window right? ie. alt tabbed out to windows?
this isnt an accurate measure if your gpu is causing the problem.
please try and run Furmark for at least an hour to confirm that it is not the gpu problem
after playing 1 round of gunz2
u got any mobo to reco?
again 1 round isnt a really indicative measure to confirm it isnt GPU problem.
also you might want to check all your fans in the case because the Fan0 reading (~140RPM) seems kinda slow. is it a chipset fan?
