Need help ASAP!
TheLegend28
Hello i had this problem when I plugged in my San Disk Cruzer 8Gb thumb drive. I cant seems to open the stuff inside. Inside contain alot of important stuff. Please guide me thanks!
The pop up will always appear once I double-clicked the thumb drive icon.
RUNDDL
There was problem starting
(alot of alphabets)
The specified module could not be found.
Please help :(
lslizzysmith002
Run CHKDSK
Hi TheLegend28,
I think you should run the CHKDSK command on your system to check the status of your drive.
