Need help: Asus mobo error code 55
saltknife
Googled for this error code 55 and understand it's RAM issue. I already tried reseating all 4 of my RAM sticks, tried inserting only 1 RAM stick in each slot, tried reseating every major component like CPU and GPU, still to no avail. Everything is still leading me to error 55 and I cannot POST.
Any experts can advise?
limcc
Clear CMOS. pull power plug, remove CMOS battery, wait 20~30 sec. then try booting with or without the CR2032 battery.
JellyPudding
if the problem persist try removing the GPU and test boot with only 1 stick of ram and see if you will be able to get past the ram code error?
saltknife
Hi all sorry for the late reply and thanks for your kind suggestions. Tried everything above, still having error 55 and cannot POST.
This isn't a new mobo, been using for about 2-3 years and was working fine. No new hardware changes at all.
Is it mobo died? Am thinking could be the ram slots somehow all died or what lol
86technie
Best bring to Sim Lim Square like PC care & solution for repair.
If at shop still code 55 than probably mobo died.
