Need help build ITX Gaming Desktop
Alphina
Hi,
Looking to build an itx gaming desktop budget <$2000.
The rig will connect to my tv so need hdmi port and i will be using wireless network.
If possible i want to get 980ti gpu.
Hope to get all components in same place, and help assemble the rig.
Including Monitor?
Alphina
I will be connect to my tv so no need monitor.
And i need os too, thanks
Asus Z97I-Plus w/i5 4590
G-Skill Rip Jaw X 1866 CL9
Samsung SSD 850 Pro 120GB
Palit GTX 980Ti Jetstream Super 6GB
Cooler Master V650 Gold
Cooler Master Elite 130
Total: SGD 1975
BIZGRAM ASIA PTE LTD
Units at Level 5 - #05-49/50/30
Sim Lim Square
[ Beside Glass Lift ]
1 Rochor Canal Road
Singapore 188504
63346455 / 63341373
sales@bizgram.com
Open from
10.00am to 7.45pm Daily
7 Days a Week
Including Public Holidays
yusoffb01
Total: SGD 1975
Sim Lim Square
1 Rochor Canal Road
Singapore 188504
63346455 / 63341373
sales@bizgram.com
Open from
7 Days a Week
Don't buy this bundle, not worth plus expensive
SSD get bigger size not 120gb
PSU avoid cooler master, get fsp, cosair or seasonic
Alphina
TS's 2k budget and want 980ti... Plus don't know he can wait for the ssd to ship or not:s13:
trento
I've Elite 130, Node 304, Core V1, Corsair 250d. 250d has the best airflow, temps. Elite 130 was the worst unless u go liquid cooling
Alphina
I see the card slot machiam berri small... can fit Palit GTX 980Ti Jetstream Super 6GB or not? never like ITX anyway....
monikernemo
Total: SGD 1975
Sim Lim Square
1 Rochor Canal Road
Singapore 188504
63346455 / 63341373
sales@bizgram.com
Open from
7 Days a Week
Why you like to recco bizgram? Hahaha
Sent from microwave oven using GAGT
trento
I don't have tat card. But Elite 130 n Node 304 can fit the longest cards, with some reduction in psu size for 304.
I think 250d can fit thick gpu. Best to search OCN various case clubs to confirm.
Actually even Air 240 got problem fitting thick gpu so not all itx cases have this limitation
Alphina
I see the Palit GTX 980Ti Jetstream Super 6GB machiam berri thick don't know if can fit any ITX case at all:s13:
trento
The 250D has a 2.5 PCI slot, which should fit the Palit, which has a similar size slot.
DawnsTear
[Mobo] Asrock H97M-ITX AC /w i5-4460 - $425.00
[GPU] Palit GTX 980 Ti Super JetStream 6144MB - $999.00
[RAM] Kingston DDR3 1600Mhz CL11 (8GB*1) - $70.00
[SSD] Samsung Evo 850 250GB - $169.00
[HDD] Toshiba 1TB/64MB - $66.00
[PSU] Silverstone SFX 600W Gold Modular 80+ - $189.00
[Case] Silverstone RV Z01 - $129.00
[OS] Windows 8.1 Professional 64bit OEM - $33.00 (G2A)
Total :- $2,080.00
Buy from PC Themes, unless stated otherwise
