Need help building a gaming PC
Marcustjw
Planning to build a gaming PC asap with a budget of $1500. I have no clue about computer tech so I really need some serious help here.Playing games like Counter-Strike Global Offensive and Dota 2. I also have no need for additional accessories such as mouse,keyboard or monitor. I just need help building a rig. No special request for design whatsoever, just need a very efficient and most worth for money gaming PC that I can get with $1500.
Marcustjw
would you suggest I get a cheaper one like $1000 or $600? Because I'm looking to play cs.go with a PC that can sustain stable and High FPS for cs.go, I have gathered information that having high fps for shooting games like cs.go is required.
Jian19
i3-4130 + Asrock h81m hds ~ $220
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $74
Zotac gtx750 ti ~ $205
Samsung oem drive ~ $21
Fsp aurum s 500w ~ $89
CM n200 ~ $60
Win 7 64 oem ~ $110
$869 buy and DIY @ tradepac ask for discount. If not sure how to DIY can bring to gs shop ask him help u assemble @ a fee
Optional stuff ~ Plextor m5s 128gb ssd @ $118
Marcustjw
I appreciate helping me with this build and I will keep it in mind, is it possible to make me a 1k-$1500 rig because I'm looking for a higher-end PC to play CSGO on really high fps. A efficient PC with around that price range, is it possible? I'm really sorry
Diaborex
unless your playing with 120fps, if 60fps sure can.
PS: 120fps maybe also can.
Jian19
The rig I put minimum fps 90 Liao..sure smooth one :o
Marcustjw
I'm looking for 200+ fps haha, it really does make significant difference. I have a professional player friend who told me that if I want to play cs properly I need to have a PC like that. I agree that it can be smooth with that amount of FPS but I would like to play on high settings at 200+ fps, but since I have $1500 budget, I would like to get the best I can.
Jian19
Hahaha I use to play CS bro...anything above 90 is smooth Liao..if ur Internet beh kan ur fps how high also no use :o
Since u wan use 1.5k so be it
i5-4570 + Asrock b85 killer ~ $357
Plextor m5s 128gb ssd ~ $118
Wd blue 1tb ~ $74
Msi 280x ~ $470
Seasonic g550 ~ $108
Fractal design arc midi r2 ~ $130
Win7 64 oem ~ $110
$1478
twasken
Most mainstream monitors max out at 60Hz anyway (= maximum display output is 60fps). Even if your GPU can pump out 200fps, it won't show on your monitor. If you really want then have to upgrade monitor (120Hz/144Hz most common but be prepared to pay a lot more).
Marcustjw
thank you so much, I will consider both rigs and really decide if I have to get the 1.5k one. but since you mentioned I can get minimum 90 fps on the 800-900 rig you put together, I will really consider it. but again, it is minimum 90 fps on high graphics/medium graphics?
Marcustjw
may I also know what does Plextor m5s 128gb ssd do? I really appreciate your help and hope you don't feel negative in any way. since people have also mentioned monitor is important due to the relevance in fps to the monitor, how much HZ should I look for, for the rig that is worth ~900
hoven00
ssd = solid state drive.
Any files you put in it will load a lot faster than normal hard drive. Put your OS and CS:GO in the ssd for a faster loading time.
MoneyFace =p
Best value
CPU+MB: Intel Core i5-4440 + ASRock B85M Pro4 @ $328
RAM: Crucial DDR3-1600 CL9 4GB X2 @ $94
GPU: PowerColor R9-290 4GB @ $549
No issue even with Crysis 3 and BattleField 4 in Full HD on MAX settings.
SSD: Crucial M500 240GB @ $175 (t258jgn)
HDD: Western Digital Blue 1TB @ $72
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Super Flower Golden Green HX-600 [80 Plus Gold] @ $108
CASE: Xigmatek Recon @ $45
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $1507
Buy others from Tradepac, #05-18.
annoymous
for cs:go and dota 2, i upgraded from 5770 to 7850 expecting a constant max fps but still exactly same fps, then i upgraded my cpu to i5 4570 and get constant max fps, from shaky 80-150 to constant 300 for cs:go. For that 2 games i would get a cheaper gpu but stronger cpu
