Need help building a gaming rig
homemadeart
Guys, i totally have zero experience in this.
Neither am i good with technology stuff, hence i need help on a new gaming rig.
My budget is 1k max. No need monitor since i have one at home.
Another question, is it possible to hook the cpu to my tv?
Hopefully it is at least able to run asassin creed black flag/battlefield 4 on max setting?
Thank you so so much.
MoneyFace =p
You must be dreaming lol....
High with AA/AF in Full HD still doable...
You need to set your TV to Game Mode in order to reduce input lag to get the best experience possible.
CPU+MB: Intel Core i5-3350P + ASRock B75M-DGS @ $271
RAM: Kingston ValueRAM DDR3-1600 CL11 8GB @ $97
GPU: Zotac GTX 760 2GB @ $320
HDD: Western Digital Blue 1TB @ $76
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: FSP Hexa 500W [80 Plus] @ $58
CASE: Xigmatek Asgard XP @ $45
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $1003
Buy and Build from Tradepac, #05-18.
royfrosty
1k is not gonna land you max settings. Not even a GTX760 can perform everything on max.
Maximum i went with the gtx760 and so call playable is Ultra settings with just 2x MSAA. And post Aliasing is turned off. And im struggling at between 45-55fps at most.
My recommendations
1k
Asrock B75m DGS + i5-3350p ~ $271
Crucial 8gb 1600mhz ~ $89
WD Blue 500gb ~ $62
Palit GTX760 2gb Jetstream ~ $348 (Get a none ref card)
CM311 + FSP Hexa 500w 80+ ~ $105
Samsung ODD ~ $21
Windows 7 Home Premium 64bit OEM ~ $115
Total ~ $1011. Buy at tradepac. DIY
