Need Help Building a Mini-ITX Rig
Jacqueline.
Needed a compact rig to do heavy excel,movies, moderate photoshop, gaming (bf3) etc.
Need a steady build-to last for the next 3 years, silent pc
monitor (looking at dell ultrasharp 24inch)
case: preferably all black,side mount (looking at Jonsbo V3+ ITX Case)
SSD 256gb
OS window7
fans to restock stock fans?
budget 2k
thanks! :D
Alternative X
Are you sure that you want the Johnsbo V3+? This case has at most 200mm of GPU clearance and you need GPUs that are longer than that for better performance in gaming. Try a CM Elite 120.
Jacqueline.
open to suggestions, althoug Jonsbo looks much nicer :s13:
Alternative X
CPU+ Mobo: ASUS H81I-PLUS + i7 4790 (506)
RAM: 2X CRUCIAL PC 12800/1600MHZ DDR3 VALUE RAM (8GB) (202)
GPU: POWER COLOR R9 270X 2GB PCS+ (299)
SSD: SAMSUNG EVO 250GB SSD (179)
HDD: TOSHIBA 1TB 7200RPM (69)
DVD-RW: LG 24X DVD-RW SATA OEM (25)
PSU: SEASONIC G SERIES 550W MODULAR (125)
Case: CM ELITE 120 M-ITX (89)
OS: WINDOWS 7 HOME PREM (120)
Monitor: DELL U2414H (359)
Total cost: $1973
Buy at PC Themes, #04-15, and ask for discounts. DIY yourself. If you can't into DIY, go to PC Care & Solution at #02-32 and ask Nigel to help you assemble for a fee.
Jian19
1.8k itx ~
i5-4590 + Gigabyte h97n wifi itx ~ $415
Crucial 8gb ddr3 ~ $100
Plextor m6s 256gb ssd ~ $184
Wd blue 1tb ~ $68
Leadtek gtx760 OC ~ $335
Superflower hx 600 ~ $108
Jonsbo U2 ~ $105
Win7 64 oem ~ $115
Dell u2414h ~ $335
$1765 buy and DIY @ tradepac ask for discount ~ if not sure how to DIY can brin to gs shop ask him help u assemble @ a fee.
Other alternative for case will be Lian Li cases
mav3rick
cm elite is one ugly looking case IMHO if u care about aesthetics.
u can consider fractal design or silverstone casings. do also consider using a SFX PSU w/ short cable kit eg. ST45SF-G w/ PP05-E to improve airflow.
